Carl Bells RV7A N947CB
Date:  6-1-2009
Number of Hours:  5.00
Manual Reference:  Grand Rapids Ref.
Brief Description:  Fuel pump wiring
Wiring the fuel pump is pretty much the same as the wiring the rest of the plane EXCEPT I decided to add a set of connectors so the pump can be easily be removed for maintenance. It is strange to me this was not a requirement, since the filter needs to be replaced or cleaned periodically and we all know the pump will not last forever. Connectors are a two edge sword, because they add complexity and a possible failure point, but Molex connectors in this application would be robust.
Molex connectors for fuel pump
Fuel Pump Switch
Fuel Pump Switch
