Carl Bells RV7A N947CB
Date:  3-30-2009
Number of Hours:  5.00
Manual Reference:  None
Brief Description:  Installing the GRT AFIS
Today the GRT AFIS came in and I just had to get it installed. The cutout was a little tight, but I made some adjustments and drilled the 4 mounting holes and did a trial fit. All is good and I think it will look marvelous once I paint the panel. I don't want to do that until I get the Garmin 696 GPS mounted. I also work on the cowl, no pictures required since it was just filling and sanding for 2 hours. More on that later.
8.4 GRT EFIS mounting
Close up
Close up
Radios are next
Radios are next
