Carl Bells RV7A N947CB
Date:  4-3-2009
Number of Hours:  3.00
Manual Reference:  None
Brief Description:  Cowl Finishing
I just took pictures of the cowl to document the work spent on sanding and filling the cowl. I brushed thinned epoxy to the inside of the cowl to prepare for a coat of paint and started spot filling the big pin holes on the exterior. The is going to be many hours of filling and sanding to get a smooth even surface for final sanding.
Coated the inside with thinned epoxy resin
Spot filler
Spot filler
More sanding and spot filler
