Brief Description: Cowl oil door installation and large pin hole fill
I also sanded the inside of the cowl where I laid up the glass cloth on the inlet ramps and did some filling with SuperFil where there where there were deep pin holes in the cowl. As you can see I also filled around the oil door. I want the door to be totally flush with the cowl surface when I’m done. No drag this way!
