Today construction took much longer than I expected, but the rear spar is basically done except for priming and final riveting. I match drilled the HS 609 PP to HS 603. Then match drilled all the hinge brackets and then match drilled the HS 411 and added the bearing and riveted this assembley with my new hydraulic squeezer, this is a great tool once you get the hang of it.
