Brief Description: Front HS Spar-Preliminary Rib & Skin Fit up
Today I worked on the front spar trimming per the plan, bending and fitting the HS 714 $ HS 711 to the front spars and match drilling the required holes. I then assembled the complete HS frame that I clecoed together and put the skins in place a clecoed the whole assembly together for a trial fit and match drilling the skins to all the ribs and the spars
