Brief Description: Wiring the forward control stick
Soldering the wire connections to the forward control stick. The stick has (5) momentary buttons
• PTT • Elevator Trim Down • Elevator Trim Up • Transponder IDENT • AP Disconnect
The stick requires input from the AP Pitch Servo for the UP and DOWN trim buttons, input from the transponder for IDENT, power, ground and AP Disconnect, (8) wires in all.
It takes me some time to sort out how to solder the wires, because the examples given don't exactly match my requirements...
