My RV-8 Build Log
RV-8
Cylinder Baffle Clips
Located, match drilled, #40, deburred the clips and engine baffles, then riveted the baffle clips in place which secured the top of cylinder engine baffles.
Cyl #2 & #4 baffle clips
Cyl #1 & #3 baffle clips
RV-8 Home
2687
Ailerons and Flaps
Baggage Door
Brake System
Cabin
Cowl
DAR Inspection
275
342
322
Fairings
54
153
First Flight
Flight Control
Flight Training
Instrument Panel
Lighting
Markings, Placards a
Paint and Prep
Phase I
Pitot/AOA
Post DAR Inspection
QB Kit
Static Pressure Syst
Tech Councilor Visit
Tech Inspection
Tires
Transition Training
Weight and Balance
Windscreen
