My RV-8 Build Log
RV-8
Resume Top Cowl Fitting
More fitting of the top cowl revealed the left rear corner (intersection) of the aft oil cooler and cyl #4 baffle is contacting the top cowl. More filing was needed to reduce this area so there is no contact of the top cowl.
Ready for more fitting attempts
Trim the corner
Inside Aft Oil Cooler Baffle
RV-8 Home
2687
Ailerons and Flaps
Baggage Door
Brake System
Cabin
Cowl
DAR Inspection
275
342
322
Fairings
54
153
First Flight
Flight Control
Flight Training
Instrument Panel
Lighting
Markings, Placards a
Paint and Prep
Phase I
Pitot/AOA
Post DAR Inspection
QB Kit
Static Pressure Syst
Tech Councilor Visit
Tech Inspection
Tires
Transition Training
Weight and Balance
Windscreen
