Brief Description: Engine Baffle Install - Baffles and Brackets
Beginning the assembly of the left aft baffle, including • the oil cooler location, • completing the install of the doubler plates on the side panels, and • cleaned up, • deburred the two brackets which install using the engine case bolts on top of the engine. • The forward bracket attaches to the engine case with a single bolt, the rear bracket with two engine case bolts.
Left Side Aft Baffle
Left Side Forward Baffle - doubler plates installed
Fore and Aft Baffle Center Attach Brackets, cleaned up, deburred
