Brief Description: Engine Baffle Install - Engine Case Brackets
Installed the forward and aft baffle mount brackets.
• Forward bracket install easy enough, just remove the appropriate engine case bolt, installed with washers and new lock washer, and torque to 96 inl.
• Aft bracket was not so easy. Due to the fuel line routing from the fuel divider to the right aft cylinder, I had to modify the bracket a bit to allow the stainless fuel line to pass through the bracket with no chance of contact. It would be a really bad day if the stainless line ruptured on top of a hot engine, in flight...
Forward bracket installed
Aft Bracket not yet installed - required some customization
