My RV-8 Build Log
RV-8
Fairings
4-23-2017
Wing to Fuse Fairings
Proceeded with match drilling the left side flap to fuse fairing, and started working on the wing to fuse fairings. After marking the fairings, trimmed to size using snips, then files the cut edge smooth.
Left Side Flap to Fuse Fairing
Winge to FUse Fairing Marked for Trimmnig
Wing to Fuse Fairing Trim Edged Filed
RV-8 Home
2687
Ailerons and Flaps
Baggage Door
Brake System
Cabin
Cowl
DAR Inspection
275
342
322
Fairings
54
153
First Flight
Flight Control
Flight Training
Instrument Panel
Lighting
Markings, Placards a
Paint and Prep
Phase I
Pitot/AOA
Post DAR Inspection
QB Kit
Static Pressure Syst
Tech Councilor Visit
Tech Inspection
Tires
Transition Training
Weight and Balance
Windscreen
