My RV-8 Build Log
RV-8
Fairings
4-29-2017
More Fairing Work
Created two fairings to cover the intersection of the lower wing to fuse. I had to remove the blind rivets in the floor of the rear seat area to get access for riveting the flap to fuse fairing. Deburred and dimpled fairings.
Wing to Fuse (underside) Fairings
Floor peeled back to rivet FLap to Fuse Fairing
a bit of dimpling ....
RV-8 Home
2687
Ailerons and Flaps
Baggage Door
Brake System
Cabin
Cowl
DAR Inspection
275
342
322
Fairings
54
153
First Flight
Flight Control
Flight Training
Instrument Panel
Lighting
Markings, Placards a
Paint and Prep
Phase I
Pitot/AOA
Post DAR Inspection
QB Kit
Static Pressure Syst
Tech Councilor Visit
Tech Inspection
Tires
Transition Training
Weight and Balance
Windscreen
