My RV-8 Build Log
Date:  3-13-2016
Number of Hours:  6.00
Brief Description:  Cowl Fitting and Trimming
Continued fitting the top and bottom cowl halves together. This operation is tricky because each action to trim something can result in a problem elsewhere. Using cargo straps overlapped the top cowl with the bottom cowl and marked a line for continued trimming. Trimmed using #60 grit and a sanding block, lots of sanding....
Left Front Top and Bottom Cowl
Right Bottom Cowl
Right Bottom Cowl
Right Top and Bottom Cowl
