My RV-8 Build Log
RV-8
Cowl
3-14-2016
Cowl Fitting and Trimming
Continued with fitting the top and bottom cowl halves. At this point, for better or worse, if there is a magic way to do this I don't know what it is. It is basically a trim, re-fit, decide where the conflict is, mark a trim line and repeat.
Sanding Station !
Another Fitting...
Bottom Cowl is wider than Top Cowl
RV-8 Home
2687
Ailerons and Flaps
Baggage Door
Brake System
Cabin
Cowl
DAR Inspection
275
342
322
Fairings
54
153
First Flight
Flight Control
Flight Training
Instrument Panel
Lighting
Markings, Placards a
Paint and Prep
Phase I
Pitot/AOA
Post DAR Inspection
QB Kit
Static Pressure Syst
Tech Councilor Visit
Tech Inspection
Tires
Transition Training
Weight and Balance
Windscreen
