Brief Description: Fuel Flow Sensor Triage - Red Cube
Attempting to locate where the red cube fuel flow sensor custom bracket can be located, meet the installation requirements by the mfg., and also enable running the fuel line from the Bendix fuel servo on the bottom of the engine to the divider on the top of the engine.
I am thinking of using (2) WDG-12 clamps on the engine mount to bolt the bracket, then bolt the fuel flow sensor to the bracket. I am still not really happy with using WDG clamps in this matter to hold the fuel flow sensor, with the fuel lines moving around from the engine movement.
Basically, I am trying out a bunch of different locates to see what I can come up with that meets the requirements.
