Brief Description: NPT fittings for Red Cube vs. Fuel Line
Up until this moment, I had not realized the fuel line exiting the Bendix fuel servo going to the fuel divider is a 1/8" line, not 1/4" line which is the size of all of fuel lines preceding the fuel servo.
The Red Cube, should be installed between the fuel servo and the divider, ideally, per the mfg. This means I need to step up the 1/8" line at the Red Cube Fuel Flow Sensor to 1/4" using an AN912 bushing,
(OR), I can install the Red Cube in another part of the fuel system which is 1/4", but this is contradictory to the mfg.
Trying to sort out the 1D vs. 2D vs. 3D for bushings and nipple fittings is a heck of lot more frustrating that it should be!!
