My RV-8 Build Log
RV-8
Baffle Air Seal Riveting
Proceeded with fitting the air seal material on the rear and left side baffles. Located #40 holes ~ 2" apart, final drilled #30, Disassembled and deburred, reassembled and riveted with large blind rivets.
Air Seal Left Side Cyl Baffles
Air Seal riveted
RV-8 Home
2687
Ailerons and Flaps
Baggage Door
Brake System
Cabin
Cowl
DAR Inspection
275
342
322
Fairings
54
153
First Flight
Flight Control
Flight Training
Instrument Panel
Lighting
Markings, Placards a
Paint and Prep
Phase I
Pitot/AOA
Post DAR Inspection
QB Kit
Static Pressure Syst
Tech Councilor Visit
Tech Inspection
Tires
Transition Training
Weight and Balance
Windscreen
