Cut the rolled air seal material in 3" width, and cut to length to fit each cylinder baffle. The idea is the air seal will over lap at the cylinder baffle joints so each baffle can still be removed if needed.
Located #40 holes ~ 2" apart, final drilled #30 for the large blind rivets.
