My RV-8 Build Log
RV-8
Conical Gussets
Have to make 2 conical gussets, one for each side of the side to front ramp intersection. Measured and cut two triangle pieces which I used the brake to form a 90-degree bend in hopefully the same shape as the air intake of the lower baffle.
The making of a conical gusset
Trying out the left conical gusset
the right conical gusset
RV-8 Home
2687
Ailerons and Flaps
Baggage Door
Brake System
Cabin
Cowl
DAR Inspection
275
342
322
Fairings
54
153
First Flight
Flight Control
Flight Training
Instrument Panel
Lighting
Markings, Placards a
Paint and Prep
Phase I
Pitot/AOA
Post DAR Inspection
QB Kit
Static Pressure Syst
Tech Councilor Visit
Tech Inspection
Tires
Transition Training
Weight and Balance
Windscreen
