My RV-8 Build Log
RV-8
Prime Instrument Panel
Proceeded with attaching the nut plates for the ELT Indicator/Switch since the rivets will be visible on the sub panel.
Cleaned the instrument panel and sub panel with acetone.
Primed the panel and sub panels with good old rustoleum.
From TSC
Panel Primed
ELT Indicator/Switch nut plates iriveted.
RV-8 Home
2687
Ailerons and Flaps
Baggage Door
Brake System
Cabin
Cowl
DAR Inspection
275
342
322
Fairings
54
153
First Flight
Flight Control
Flight Training
Instrument Panel
Lighting
Markings, Placards a
Paint and Prep
Phase I
Pitot/AOA
Post DAR Inspection
QB Kit
Static Pressure Syst
Tech Councilor Visit
Tech Inspection
Tires
Transition Training
Weight and Balance
Windscreen
