My RV-8 Build Log
Date: 9-14-2014
Number of Hours: 3.00
Brief Description: Avionics - ADAHRS and EIS Installation
Finalized the installation method for the ADAHRS and EIS...
Since I am using AN3 bolts for mounting the ADAHRS and EIS to the brackets, I located the needed nut plates required (8) total, 4 for each mounting bracket pair for the ADAHRS and EIS.
Due to general lack of foresight on my part, I did not make the mounting brackets long enough to use 'plain' K1000-08 nut plates, I need some K2000-08, and also I found some MK1000-08, which will work nicely. Used a combo of K1000-08 and K2000-08 on the ADAHRS brackets, and used the MK1000-08 for the EIS. • Located the holes for the nut plates, generally secure the nut plate to the bracket using a AN3-4 bolt, and used the nut plate as a #40 drill guide. • Countersunk the #40 holes for the nut plates on the face of the mounting brackets. • Cleaned and deburred edges. • Reassembled the brackets and nut plates. • Riveted nut plates using pneumatic squeezer using AN426 3-3.5 • Installed the brackets on the aft side of the baggage compartment skin using the AN8R8 screws, washers into the mounted nut plates (earlier work).... • Installed the ADAHRS and EIS using AN3 bolts (AN3-10 for ADAHRS, AN3-4 for EIS) with AN960-10 washers.
ADAHRS and EIS Installed
Nice and Tidy
View looking down
