My RV-8 Build Log
Date:  8-11-2014
Brief Description:  Rudder Light Fitting
Determined the hole size for mounting the Aeroled sun tail light. Drilled a pilot hole in the center of the fiberglass rudder bottom cap, and final drilled using unibit/step drill.
Test fitted the light to make sure it is going to fit properly.
Hole for Aeroled sun tail light
Test fitting the light
Light looks like it was custom made for the fairing
