My RV-8 Build Log
RV-8
Prop Governor Install - Part 1
Received the new 2" prop governor studs from A/S - West Coast so they took a week for transport to Columbus, GA.
Installed the new 2" studs by simply running the nut to the stop, and then inserting into the governor mounting pad.
New 2" studs for prop governor
Installing the 2" studs
New 2" studs installed
RV-8 Home
2687
Ailerons and Flaps
Baggage Door
Brake System
Cabin
Cowl
DAR Inspection
275
342
322
Fairings
54
153
First Flight
Flight Control
Flight Training
Instrument Panel
Lighting
Markings, Placards a
Paint and Prep
Phase I
Pitot/AOA
Post DAR Inspection
QB Kit
Static Pressure Syst
Tech Councilor Visit
Tech Inspection
Tires
Transition Training
Weight and Balance
Windscreen
