Brief Description: Engine Mount Rremoved,Fuel line installed
To remove the engine mount, remove and discard te cotter pins, back off the nuts, use a little liquid wrench on the bolts, let set for five minutes, and gently tap out the bolts until flush with the mount, and pull the mount straight off the fuse. Found the firewall facing part of the engine mount in contact with the firewall had surface corrosion... fixing that before reinstallation.
Fuel Line installation inside the fuse looks complete... testing will tell if the flares are good, no leaks.
engine mount removed - needed to drill hole for fuel line connector.
Engine mount cleaned-up
Fuel Line Boost Pump to Firewall Connectior Installed.
