My RV-8 Build Log
Date:  5-8-2012
Manual Reference:  82
Brief Description:  Flare and Install Fuel Line Filter to Boost Pump
Received grommets today, so I can install them on the fuel line from the filter to the boost pump, then install the connectors and sleeves, flare the ends of the fuel line, and finally install the line.
Flared the line at the filter side first, then the boost pump side last. Installed at the filter first, then installed at the boost pump. After the great struggle to make the line, it fit perfectly. Then, installed the grommets in the gear leg tower, boost pump side first, with a bit of encouragement, then the filter side grommet last. Seems the line is very well secured, and is not going to rub on anything such as the fuel vent line in the gear leg, or the fuse floor.
Flared and ready to install at boost pump
Flared and ready to install at filter
Installed fule line with grommet installed in forward gear leg tower.
