Sanded the foam core on the RH wing skin in prep for the final layups. I spent a lot of time sanding the old reinforcement plys to smooth out the area. I also q-celled the foam to seal it prior to laminating. I also q-celled a couple of areas of the foam edges that had minor voids in the LH skin and sanded the perimeter of the existing plys in prep for laminating
RH Panel after sanding and sealing
LH panel ready for laminating note perimeter sand prep
