Layed-up RH top wing skin wing reinforcemnet inner skin. The lay up is one ply of uni and one ply of bid. I layed up the plys on 18 inch wide tin foil. After the plys were wetted out a put a second piece of foil over the two plys and squeeged that down. I then traced the shape of the final layup on the foil sandwich and cut it out. The bottom piece of foil is removed and the laminates are placed on the wing skin. After the laminate was placed and squeeged down the top piece of foil was removed and the laminate touched up as required. I decided to try some peel ply on this laminate. If it comes out well I will use the peel ply on the LH side also.
