Brief Description: Tail cleanup; EIS mounting hole; misc.
I spent some time deburring, sanding, filing, prepping and priming the rudder stops, elevator "up-stop" angle, and vertical stabilizer connector plate and spacer.
Yesterday I located an accurate set of measurements for the Grand Rapids Technologies EIS unit, so I cut out the rectangular hole and four mounting holes in the left cockpit side cover.
Left side cover, with new rough-cut holes for the GRT EIS.
