Brief Description: VS attach plate; EFIS backup battery jack
To complete the VS assembly, I riveted the Vertical Stabilizer attach plate and spacer to the VS forward spar.
Next, I fabricated and drilled a doubler plate that will go under the EFIS backup battery charging jack on the right mid-cabin cover.
I'd intended to work on preparations for rotating the fuselage upside down this evening, but a line of Level 5+ thunderstorms containing hail was approaching, so I had to leave the workshop and put my truck in the garage. (I'm getting tired of the extraordinary storms we've been having for almost a week around here...)
VS attach plate and spacer are now riveted to the VS forward spar.
Doubler plate for the XLR power jack is test-fit on the right mid-cabin cover.
