Brief Description: Landing light; Dynon remote compass mount
Painted mounting plate using high-temperature gray enamel. Countersunk nuplate holes in remaining retaining strip and drilled screw holes to full size. Painted one side of retaining strips.
Determined mounting location for Dynon EDC-10 remote compass (aft end of L wing tip rib). Marked rib for wiring hole and grommet. Since the compass has to be aligned with the panel-mounted instrument, I plan to install the wiring harness and OAT now, and wait to mount the compass tray until the wings are on and the panel is underway.
The Dynon remote compass tray will fit here. (Note: wing is upside down in this photo.)
