Bob's Web Site
S-20 Raven
Text 05C-03
Rib Stringer installation
Both Wings----
Slid Both Out board Stringers into the wing from the outboard side and cleco'd to up-er and lower Tabs on Ribs #3 thru #11.
Riveted inboard Rib Stringers to upper and lower tabs of Ribs #2 and #3. Modified inboard Stringers to fit.
Modified Tip Rib Stringer per figure 05C-18. Cleco'd in place
Riveted Upper and Lower stringers to Ribs.
Riveted all ribs (#2 to Tip) to spars and/or clips
Text 05C-05---
#44. Glue Scupper and Capture Ring to Underside of Upper Root Skin. Cleco'd Cover Ring in place.
S-20 Raven Home
1363
Avionics Panel
Covering
Fuel Trailer
336
Rans S-20 Kit
210
