Bob's Web Site
S-20 Raven
Text 05B-01
Aileron Bellcrank & Cable Install
As per manual, installed Aileron Bellcrank and Cable Install.
Check for freedom of movement.
Routed cables through the ribs and the Cable Rub Block as per Figure 05B-13
Dimpled and deburred all the required holes for Ribs #1 & #2.
Had to replace about 10-12 rivets on the upper and lower root skins. They did not seat well.
Aileron Bellcrank assembly
S-20 Raven Home
1363
Avionics Panel
Covering
Fuel Trailer
336
Rans S-20 Kit
210
