I fabricated the left and right Rudder Stops from aluminum angle supplied in the kit. Similar to the Horizontal Stabilizer Attach Bars Support Angle, the first step was to accurately mark on the aluminum angle where the cuts were to be made based on the figure in the plans. I cut away the unneeded material using my band saw, then deburred the edges using the bench grinder with the scotch brite wheel.
