Brief Description: Elevator Front Spars, Ribs, and Trim Access Dbler
I dimpled the #40 holes in the web and flanges of the left and right front spars.
I dimpled the #40 holes in the forward, top and bottom flanges of the left and right root ribs.
I dimpled the #27 holes in the Trim Access Reinforcement Doubler using a #6 dimple die set. These holes will be used to attach the trim access cover plate using #6 screws and the dimples will allow the screws to be set flush.
I dimpled the #40 holes in the Trim Access Reinforcement Doubler and the lower flange of the Reinforcement Doubler Brace.
