Brief Description: Horizontal Stabilizer Stringer Web Assembly Part 2
I riveted the Stringer Web Assembly to the front spar using the universal head rivets called for in the plans. The two inboard Inspar ribs were not riveted yet because those holes are shared with the nose ribs and will be riveted later. In the first picture you can see that those ribs are just clecoed in place.
All the remaining Inspar ribs were riveted to the front spar. The two outboard nose ribs were also riveted to the front spar. The remaining nose ribs will be riveted later.
The next step is to dimple the skins and prepare the inside of the skins for priming.
