Brief Description: Horizontal Stabilizer Hinge Bracket Asmbly Part 1
I clecoed the VA-146 flange bearing in between the two hinge brackets and final drilled #30 the six holes common to all the parts. Both holes in each of the bracket flanges were final drilled #12.
After deburring the holes on both sides of all three parts, I clecoed them back together to be riveted using AN470 universal head rivets.
