Brief Description: Vertical Stabilizer Skin Riveting Part 2
We clecoed the rear spar assembly to the vertical stabilizer/skin assembly and riveted the aft edge of the skin to the rear spar. Once this was completed, we riveted the rear spar to the tip rib and root rib with1/8 universal head rivets. The final step was to rivet the rear spar to the middle VS-707 rib using LP4-3 blind rivets.
This completes all the steps in Section 6: Vertical Stabilizer
