Brief Description: Battery and engine grounds, baffles
Fabricated ground cables for battery to engine, and engine to fuselage. Cut to size and crimped on lugs and drilled holes to size. Began work on engine baffles starting with the one for cylinder #4. Fit, drilled and dimpled parts as directed. Got stuck on how to locate oil cooler because directions only say to mount as high as possible. Decided to quit for the day to do some research.
