Worked on cylinder #4 baffle. Settled on location for oil cooler and layed out on the baffled. After completing most other work on the baffle I cut the hole for the air to the cooler. All work done except final riveting of aft and side baffles since directions say it may be easier to fit the cowl prior to final assembly
