Brief Description: Mount for Fuel Cube, mounted ground block
Fabricated a mounting brackett for the fuel cube from 2X2" aluminum angle. Drilled holes for mounting cube to angle. Located angle on firewall and drilled out 2 rivets on the firewall bracing angles to mount fuel cube brackett to. Drilled a third hole for the angle to the firewall. Riveted the fuel cube brackett to the firewall. Made final measurements for the fuel lines. The VA-139 fuel line works perfectly between the fuel cube and the carburetor. Need to order the fuel lines for pump to fuel cube, and gascolator to fuel pump. Determined location for grounding block and drilled holes. Attached ground block to back side of firewall.
