Drilled holes for tail light nount through fiberglass. Clearanced top and bottom so nuts can fit in recess. Countersunk six holes for blind rivets in mount and riveted in mount with blind rivets. Began working on rudder top fairing. Cut a little at the rear apex so that it would fit into rudder top. Fairing is about 3/16" short at the front which will require fiberglassing to match up. Drilled holes for VS top fairing. Marked off excess and the rear and cut off. Began working on how to mount the VOR antenna.
