Made final preparations to glue the windscreen on. Made a few taping changes to the windscreen and then used 100 grit sandpaper to rough up the areas that will take primer and glue on the windscreen and also on the fuselage and roll bar. Primered the windscreen, fuselage and roll bar after first cleaning it with the Sika accelerator/cleaner. Waited about 30 minutes prior to setting the windscreen onto the fuselage. Placed windscreen on and put spacers between roll bar an windscreen and clamped with spring clamps. Applied glue first to the area where the windscreen meets the fuselage. Did not use spacers here since it really is a fillet to fill the gap. Applied glue to the windscreen first from the backside of teh roll bar and then the front side. Very hard to see whether all gaps were filled but it looks pretty good. Cleaned up the fillets using Sika cleaner and my finger as I did with the canopy. Cleaned up the excess mess and called it a day, the windscreen is on.
