Worked on prepping the windscreen and fuselage for gluing on the windscreen. Sanded the area on the fuslage where the windscreen meets the fuselage and roll bar. Used the die grinder on the roll bar to get it down to bare metal. Took a long time. Did the final taping of the windscreen on both the inside and outside, which also took a long time.
Also sanded the upper cowl at the side hinge line so it meets up with the lower cowl nicely. Still have some gaps that I don't like, don't know what I can do about them at this point. Guess this is why they call them Experimental AMATEUR Built airplanes...
