Fabricated bracket to hold the control cables as they pass by the middle subpanel. Used the original braket which could no longer be used because of location of SL-30. Measured distance to clear SL-30 and cut out opening. Added .063 pieces to each side of the bracket to extend up to subpanel and riveted pieces onto bracket. Drilled holes for AN3 bolts and attached bracket to subpanel. Should work great. Tidied up some wiring.
