Installed BNC connector on antenna end of coax for Marker Beacon after cutting coax to length. Attached to antenna. Put instrument panel back in airplane to be able to decide proper lengths of wiring and routings. Pulled coax for Nav antenna from aft of fuselage through left side conduit. Installed the BNC connector and attached to SL30 lead. Installed a WG12 size adel clamp on bottom of subpanel to help with routing of coax for Nav and Marker Beacons. Cut coax to length and installed BNC connector for Marker Beacon and assembled. Decided to do some wiring of other things. Cut wire to length and installed a tab terminal for the Hobbs ground. Drilled a hole and installed a 3/8" grommet to run Hobbs wires through. Attached the ground to the Hobbs. Cut a length of red 20 ga wire for the power to the Hobbs, installed a female tab terminal and attached to Hobbs. Other end left for later. Wired boost pump. First screwed the ground wire to one of the bolts holding the pump to the firewall. Attached a female tab terminal to a length of 18ga red wire for the power. Decided to tackle one of the power pins for the VP400 for the boost pump. Crimped on the pin which was easier than I thought it would be and inserted into the power connector. Spent a lot of time today cleaning up routings and zip tieing things. Although I didn't get as much done today as yesterday I'm still pretty happy with this weekends work.
