Brookes Web Site
Date:  3-17-2011
Number of Hours:  3.50
Manual Reference:  14.1.4
Brief Description:  Balance ailerons
Balanced ailerons attaining a "bottom level" when suspended by hinges. Had to add about 9 0z. of weights to each one. Used wheel balancing "stick on" weights purchased from automotive store. Stucks weights over steel rod on inboard end. Filled weights with micro and covered with 1 bid and peel ply.
Treated strake ends and access hole with 1 bid and micro
String of weights glassed onto aileron
Additional weight covered by peel ply
Edges treated
Edges treated
Copyright © 2001-2018 Matronics. All Rights Reserved.
