Completed rigging of pilot side aileron. Added a bracket between firewall and aileron cable support bracket to straighten up the cable forward of where the clamps are attached. Secured with tiewrap wrapped in nylaflow.
Drilled holes through gear bulkhead and firewall for pilot rudder cable. Installed 3/8 aluminum conduit from the floor to where the cable enters the gear bulkhead to add more rigidity to rudder cable. Ran rudder cable through fuselage and through wing. Attached cable to rudder horn.
