Added a 7 inch x1x1/4 aluminum bar to lower sides of pilot seat back. I wanted to mount the seat back as high as possible. The factory installed aluminum hard point did not extend low enough in the seat back to allow this, so I simply caboed in another bar on top and all the way down to the lower flange. Covered with one bid.
Mounted seat bottom to aluminum plates. Hot glued bottom of seat to seat rails. Positioned seat in fuselage to allow for proper movement and also placed the for-aft position so that with seat fully aft, the bottom-back hinge point was approximately 2 inches forward of door carbon beam.
