Brookes Web Site
Date:  10-5-2007
Number of Hours:  3.00
Brief Description:  Drill hole in fuselage for torque tube
Maked and drilled 1 1/8" holes in fuselage lined up with torque tube for elevator. Removed canard and cut the piece out above the hole. Shaped foam additions to those pieces, glued them to the others, and then glued the assembly to the bottom of the canard and glassed both sides. This is done to minimize air intrusion into the fuselage in flight.
